JEFFREY
200 points
Posted on - 12/14/2012
A problems running sonos on Ubuntu. It seems like the sonos application is not compatible to Ubuntu operating system. It crashes and never responds to the computer server when being run. What would be the possible solution to make sonos run on Ubuntu OS? I need some help. Thanks.
Jeffrey.
A problems running sonos on ubuntu.
I will help you fix the issue with Sonos application on your computer running with Ubuntu operating system. I suggest you to check the following:
>>Make sure you are using the latest version of the application on your computer.
>>The latest version is Sonos 3.7
>>The previous versions had some compatibility issues with Ubuntu operating system.
>>Make sure you have enough memory on your computer. Programs may hang due to insufficient memory.
This should fix the issue on your computer.
Thanks and regards,
Skarbos Jay.
