Problems with saving Outlook items
Asked By 300 points N/A Posted on -
I have been using Outlook application for long days. Its PST file can store different types of files with this application. I got the following unknown error message last night when I go to save some of the Outlook items:
“Task 'Microsoft Exchange Server – Receiving' reported error (0x8004060C): ‘Unknown Error 0x8004060C'”
Many other associated errors Outlook starts prompting after this error. Outlook is running very slowly.  I need help to fix this problem.
Answered By 20 points N/A #104114
Hi Justin, error 0x8004060 happens because your outlook is already full. Microsoft give only 2 GB . It is advisable that you will delete some of the files that you no longer need.  It also means that your .pst files is not accessible and perhaps your files are corrupted already.  Pst that are damaged is already useless unless it is repair.  YOu can repair it with the help of outlook inbox utility which is called Inbox Repair Tool or Scanpst.exe, but it cannot repair severe damaged pst.
Because Inbox Repair tool does not work always, you have to use the third party  PST repair tool. You can download it from this link: http://www.pstscan.com.  It will repair totally and recover your lost files.
