malcdavid
Posted on - 02/15/2012
Hi experts
On our SBS 2003 server, I had installed LCS 2003. We had some Vista workstations but Messenger 5.1 would not run with Vista. We canned LCS in support of Office Communications server. To utilize as a secondary domain controller, we bought one more server and then on that machine we installed OCS.
After months of problem by Vista and OCS we went back to LCS 2003 again but we were unable to use it again, yet when we installed it on the secondary DC.
Then we uninstalled LCS 2003 from SBS 2003 and ran OCS 2007 on second domain controller. It worked but with many troubles. Then we uninstalled OCS 2007 from second domain controller and again installed LCS 2003 that was originally installed on SBS onto the second DC. Â The installation was good, but for some reason the clients were not able to log in.
LCS and OCS left all of the SIP names in active directory after ending all of the install/uninstall and I was unable to remove them. Please give me a suggestion. Thanks in advance.
Problems with SBS 2003 and LCS 2003
Hi
The problem looks like there is some mistake in the configuration of your cookies or in the internet connection options in the control panel and you need to check that settings first. In internet options there is cookies options check whether it is checked or not and if it is correct then the problem is with your window. Your window might not work properly or your software is not working properly so let check first your internet options and then check whether your window is working properly. Hope this will sort out your problem and you will get rid-off writing the password again and again. This is really very bad to write the password and user name again and again.
The problem you are facing is as like you said you have found this has happened due to stardock software’s. So check it now if this happens due to stardock then uninstall the stardock software and then again install the stardock software and before installing the stardock software’s must run this software and check whether this problem has resolved or not. If not then you have to re-install your window and then install these thing will working properly as you also said your window crashed so it is best option to install the window again and then check this solution solve or not.
