carlin
10 points
Posted on - 01/29/2012
Hello, I am working with Blend 4 (final edition) Silverlight Q1 2010 SP1 and I cannot revise scheduled templates on it.
First issue: if I do "change added layouts" -> "Edit TimelineTemplate" -> "Edit a copy" (cf 1_EditTimelineTemplate.png), I have a ControlTemplate empty (cf 2_EditTimelineTemplate_Result.png).
Is this normal?
2nd issue : Because of my primary issue, I've changed the TimelineTemplate from "Seven theme" found in "TelerikRadControls for Silverlight Q1 2010 SP1ThemesWindows7ThemesWindows7Scheduler.xaml
and I receive an error message: (cf 3_EditTimelineTemplate from SevenTheme.png)
Please help.
Problems with scheduler templates in Blend
Have you tried changing the template?
Download any other template from the internet or make any other just for the test purpose.
The newly made template must not contain anything else except for the code that is giving the error.
Save the template and see if it runs the code without any error or not.
If it does then it means that there is something wrong with your older format.
But if it gives the same error then there is a chance that it is pointing to something that is not present there. Mostly it happens when you are pointing to a null variable that is not having any value what so ever during the execution of the template.
