Waqas Riaz
10 points
Posted on - 08/21/2011
Hello!
I have just downloaded the setup of BSR screen recorder . When i try to install it , setup paused at 41% . I have tried many times to install it, each time the same event happen. I have re-downloaded the setup, but again problem is not solved . I am unable to understand the problem, whether it is with software or with windows file. The following are the specifications of my PC,
Pentium IV with 2.8G Hz, 512MB RAM
Windows XP Professional SP2
Direct X 9
Following screen appears,
BSR Screen Recorder – Install
Copying files into temporary folder and expanding into install directory…
Please help i need to install it as soon as possible.
Problems while installing BSR screen recorder
Dear Waqas,
Your problem is a generic one and this type of problem happens when there is an error with the software setup. Some times also because of the windows these errors are shown but as you told about your system configuration this software surely have to work. But now I am going to tell you two things and you can follow those and then check out which one works.
First of all you can check the requirements of that BSR from the website or read file and then match those from your computer system. If any one of those reaming then there is a fault of your configuration.
Other one is that you can download it from any other source and then check it because some time there are some corrupted files and those files create a hindrance in the setup of that program. So try to download from an authorized site.
Thanks
If you are installing form a CD/DVD then make sure that your CD/DVD is error free and it is working properly. You can first copy the uninstalled program to your computer and then from there you can install the software in this case. And your software will run fine. If it gets error message while your are coping your software then make sure that your DVD drive is working fine or you CD/DVD contain some error.
Also you can check that you full fill all the program requirements while you are installing your software. Make sure that you have enough hard disk space to install your program. Also check for all the required applications for your program. Most of programs use .NET framework to work so you need to check it also. Also you can update any hardware if required any update.
If you are installing form a pen drive then you need to check is that your program does not contain some errors and is error free. It does not contain some virus and you have a full version of your program. After you have checked all of these things you will be fine with your program.
Michal Joran.
If you think install stopped or paused at that percentage, try waiting a little longer because sometimes setup takes some processing a little longer. But if setup didn’t resume after like 10 or 15 minutes, cancel the installation. After this, try cleaning your system first. Download the free version of CCleaner and install it. Once installed, start CCleaner and clean your system.
When it is finished, close CCleaner then open your web browser and download the latest version of BSR Screen Recorder. The latest version at the moment is BSR Screen Recorder 6.1.9. It supports Windows Millennium, Windows NT, Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8, Windows Server 2003, and Windows Server 2008. It requires a Pentium processor, 512 MB RAM, and 20 MB free space.
The download page provides two downloads. Both downloads supports Windows XP but the first one supports 64-bit Windows XP only. If your operating system is 64-bit, download the first one that supports 64-bit Windows XP. But if you are using 32-bit operating system, download the second one. Don’t forget to check “I accept the Terms and Conditions” before clicking the download button.
See if the new version works. If you still can’t install it, try to disable your antivirus temporarily then try installing again. See if this works. Also, try updating your operating system to Service Pack 3.
