Problems While Installing Software On My Smartphone
Is anyone familiar with Galaxy S i900? I’m having some problems installing software on my Galaxy S. Every time I open the installer I get a pop-up message “Error Parsing package”. Can someone give me a hand here? Thanks!
Answered By 0 points N/A #130315
Dear Madmoore yes Galaxy S i900 is a famous in the android fanatics. The problem you are stating can be resolved following some steps. First of all backups using Astro file manager then just root and install Google experience/Google Market and hopefully you won’t have that problem again.
This information is given by understanding that you have an adequate experience of using and probing the root of android based mobile.
If not you can have a detailed look at a step by step guide here. Just ignore the cell they are mentioning and the same method will work for your mobile also.
