Problems with .XML instruction to the internet
 Hi, I’m thumping my head beside a brick wall. I corrected .catx folders to begin edition I want, excluding that I can't picture out how to contain the Body / Details for scheduled time (the huge section you can type in at the bottom when you create an appointment). When I transfer the calendar into XML, it is enclosed by a tag, but utilizing that in the resource doesn't function. Can anybody explain what is happening? Or let me know that it's not possible? Why there is no XML instruction for this anywhere on the internet? Please recommend suggestion
Answered By 20 points N/A #105660
Hallo  Genie Bottler,
Your question seems a bit vague because all I can see is that you are saying that you are experiencing problems with XML, but you have not mentioned any program that you are using that is resulting to the problems you are getting which will establish the basis with which to try and help you solve your problem.
So let me just guess that you are using a program like Dreamweaver which uses XML codes and you are having trouble when you try to access its pages on the internet, the I think the problem will be caused by how you transferred the files to the remote site on the internet.
But to be able to help you well, please state the application that you are using.
__
Regards
Mahesh Babu
