bryan night
Posted on - 11/07/2011
Have you downloaded Flash Player 11 but are unable to view in CS5? Do you know how to make Flash Player 11 work in CS5? I have incorporated Flash Player 11 to Mac Lion 10.7.2.OS.
On my browser, when I go to the Adobe test page, it says that I already have flash 11 on my PC.
What could be the issue here?? How to fix this?
lee hung
75 points
Problem with Flash Player 11 unable to view CS5
Hello Bryan,
Maybe the flash player that you have installed is not compatible with the mac operating system that you are using. You may have downloaded and installed a flash player that is meant for windows operating system on mac OS.
So I will suggest that you Google on the internet for flash player that is meant for the mac OS, download it and install it on your computer and see if the problem will be resolved.
Also, just try restarting the computer. Maybe after installing you did not restart the computer for the changes to take effect.
__
Regards
Lee Hung
Hello Bryan night,
I think, the Flash Player you have installed in your computer is not supported in Mac Lion operating system. All the Flash Player you can found in internet are not compatible with your operating system.Find a latest Flash Player compatible with your Mac Lion and Install. Then, you will be able to view in CS5.
Thank You. Best of luck.
Paul Jolie.
