bellaross
Posted on - 02/27/2012
Hello all.
I need to install the "Procaster" software which comes from "Livestream.com". Unfortunately, I keep receiving an error message while trying to run the executable file to install the program. It reads:
"Error opening installation log file. Verify that the specified log file location exists and is writable."
No other option is available to verify this. The only thing I can do when this message shows up is to click the red "X" and close the window down. Any help will be greatly appreciated. Thanks in advance.
Procaster Error in opening installation log file
I think you need to check first if your computer is able to run this application. The usual cause of a not functioning program is system incompatibility that is why if you decide to install something on your computer you need to know first, what are the system specifications for that particular software so you can upgrade your hardware if it is necessary or you may need to install additional applications.
You must have at least a Pentium Core 2 Duo processor to run Procaster or if you have a higher processor much better.
This application can be installed on a machine that has a Windows XP, Windows Vista, Windows 7, or Mac OS X 10.5 or higher. Your computer must have at least 2 GB RAM installed on the CPU. The more RAM you have, the better.
If your computer meets the above requirements, then there’s no problem with installing Procaster.
