Procedure entry point in Linux 11.10 Ubuntu not found when start firefox
Posted on - 11/01/2012
Hey guys,
I need you to suggest me some solutions in this matter.
I’m using a fully updated Windows vista in my PC. Recently I updated my Firefox to 8.0.1. My previous version 6.4 was working perfectly. But, when I start Firefox 8.0.1 I’m getting an error message that states:
"The procedure entry point PORT_LoadLibraryFromOrigin could not be found in the dynamic link library nssutil3.dll". Now when I click the OK button four times, I get this standard windows error message stating: "A problem has caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Usually I like using Linux 11.10 Ubuntu. I just install Windows to run updates. I wanted to run some sophisticated photo editing software, which is why I needed Firefox. I’ve tried a reinstall of my Firefox 8.0.1- no result.
Are you familiar with this type of problems? Then please help me. Waiting for your answers.
THANKS A LOT!
