Procedure For Outlook 2007 Unblock Sender Online
Hello everyone, I blocked one of my contacts accidentally; now I am wholly blanked how to unblock him. Kindly provide me the steps for Outlook 2007 unblock sender online.
Don’t get worried you can easily unblock and again block any sender from your contact. Follow the steps:
1. Launch Outlook 2007.
2. Choose the tools menu.
3. Click Options.
4. Choose the Preferences tab and select Junk Email button.
5. The dialog box will appear with the Junk E-mails.
6. Click the Blocked Senders tab.
7. Hit the Email address that you want to unblock and select Remove button.
8. Select OK.
If you use Microsoft Office Outlook 2007 as email client and you blocked a sender or one of your contacts by accident, here’s how to fix it and unblock the sender. In Microsoft Office Outlook, go to “Tools” then “Options”. In “Options” window, in “Preferences” tab, under “E-mail” section, click “Junk E-mail”.
In “Junk E-mail Options” window, go to “Blocked Senders” tab then select the name you want to remove and click “Remove”. Click “OK” all throughout and that’s it.
That sender or contact you accidentally blocked will now be unblocked. You will now be able to receive messages from this sender. When you block a sender or contact in Microsoft Office Outlook, messages from his or her email address will always be treated as junk and will go to the “Junk E-mail” folder regardless of the content of the message.
The message will not be deleted but will appear like SPAM and will be filtered out of your inbox.
