Procedure On How To Reset Hp Printer
Hi. Kindly let me know how to reset my HP printer. Many issues are cropping up while handling print commands on it, and therefore, I want to reset my printer.
Power cycling the printer might help in the first place, which may fix the issues arising. If the problem persists, you can follow the steps mentioned below to guide yourself on how to reset the HP printer. To reset your printer, all you have to do is –
Step1: Press Resume button three times, while pressing the configuration page button.
Step2: Wait for a moment of about 20 seconds and then to turn off your printer, hit the power button.
Step3: Now, disconnect the power cord from your printer.
Step4: Again, Wait for a moment of about 20 seconds and reconnect the power cord, you disconnected, previously.
Step5: Now, hit the Power button, again, to turn on your printer.
Notifications
