What is the procedure to restore iPhone file system, Is there any file recovery software that will recover files after an iPhone has restored to factory settings. Please help me, as I have no idea on how to do it further I need the files to be restored urgently, Waiting for valuable inputs. Thanks
Procedure to restore iPhone file system
Hi there,
I know it’s never easy to lost all data from your device especially if it was done unexpectedly like accidentally deleting it, improper upgrade, jailbreak and factory setting restore. In your case you have restored its settings.
You don’t have to worry there is a software to the rescue which can retrieve all your files easily such as your photos & videos, contacts, SMS, call logs, memos and calendars. You can download the software for free then try it.
Click for downloads.
Good Luck!
