Procedure To Make An Account On Whatsapp Easily.
I want to socialize with my friends and family on Whatsapp. I have an Android phone which works fine and need to make an account on Whatsapp. What is the simplest procedure to follow?
Download Whatsapp application from the Play Store by signing in via your Google ID. Then, open the App from the tray and follow the instructions promptly. You would need a SIM which is inserted into the same phone on which you are installing Whatsapp. It will prompt you to fill some security details and send you an OTP. The app will automatically read OTP and assists you to fill your display name as well as the picture. You can send a message to anyone on Whatsapp by connecting to the internet.
