Procedure To Reset Internet Explorer 8in Windows.
Internet Explorer is the default browser in Windows but after using it for a long period, it takes too much time to start. How can we reset Internet Explorer 8 to default?
Many changes are possible to customize the browsing experience in IE. You can also reset IE 8 settings to default version when it was first installed in PC. To do this, close all IE windows and select Internet option from Tools button. Then, select Reset from Advanced tab and click Reset on the next dialog box. Close after the application of default settings and click OK. Restart to apply changes to your PC.
Resetting Microsoft Internet Explorer back to default is pretty easy. This can be very useful for troubleshooting problems that may be caused by change in the settings after installation. Just remember, resetting Microsoft Internet Explorer is irreversible. Any changes you made to the browser will be lost for good.
There are two ways to reset Microsoft Internet Explorer: first is with the browser open and second, from the Control Panel without even running the browser itself. Here’s how to reset the browser from the Control Panel without opening the actual Microsoft Internet Explorer browser. Click “Start”, “Control Panel”, “Network and Internet Connections”, and then “Internet Options”.
In “Internet Properties” window, select “Advanced” tab and click “Reset” at the bottom.
In “Reset Internet Explorer Settings” dialog, click “Reset”. Wait until Microsoft Internet Explorer completes applying default settings. When it is done, click “Close” then “OK”. You need to restart your computer for the changes to take effect. And that’s it.
