Procedures to import mail thunderbird dans lotus
Hi there,
I must import mail thunderbird dans lotus ; and i am looking for a simple way to make it happen after many failures
many thanks to all experts
Hi there,
Dear Zubin
I have read your question and I understand that you are searching for a way to import your Mozilla Thunderbird email to Lotus notes.
To import emails manually from your thunderbird email:
On your thunderbird email menu click on tool, then import and the wizard will ask you if you want to import everything, or specific things such as address book or emails, chose what you want to import and click on next, then select the type of file you would like to import, then click on next and when the import is done click on finish.
To import emails from your thunderbird with a program that can convert your emails and your contacts.
http://www.connectedsw.com/Overview/57262
Notifications
