Procedures for importing/exporting base MySQL converter deliverables
What are the procedures followed in importing or exporting base mysql converter deliverables into corresponding destinations such as Microsoft Access or the mysql database?
To import or export Databases inside or outside of MSQL, you can use the new MSQL workbench version. First, click "Migration" button, then follow the steps (select your source, the object you want to migrate, choose the data, report migration). Also you can use" FlowHeater" to import and export databases without SQL knowledge.
You can use EMS Data Export 2005 for MySQL tools. To use this tools you have to follow the steps below you have to:Â
1. set connection options
2. Select tables
3. Specify queries
4. Select export data format
5. Select fields to export
6. Set export options
