Proceeding with the operation will erase contents of your hard drive.
I install window XP in system now I am trying to open any drive when I do double click at any drive then I receive below error. I am very confused about this error because if I do very small mistake I can lose all data. Please if any one knows its proper solution tell me.
Warning
            Proceeding with the operation ‘Delete’ will erase the contents of your hard drive.
            What do you wish to do?
Best Answer by CristaSmullen
Answered By 0 points N/A #95794
Install windows XP again and then try to open them. Install a full version of windows XP. Do not install theme version or any editing version. Give time for windows to detect all drives.
At the time of installation make sure all drive partitions are safe just like before. Do not changes drive letter or partition size at this time. Then only format C drive or that drive you are using for windows installation before.
If it is not working then install updated antivirus from other source after windows installation. Then scan full computer and delete all viruses.
Other option is Go to control panel click on administrative tools then services then find “Shell Hardware Detection” and click on STOP. Then restart computer and try to open drives with explore command.
Answered By 0 points N/A #95795
Dude, it's a joke.
Did you even bother to Google the error message?
