What are the steps to follow in making a video tutorial to assist amateur students and individuals who wish to learn the digital 3D modeling? I would like to make a video tutorial on how to modeling a goat. What should be the don'ts to observe and any other advise to consider in executing these tasks. Thank you.
The proceeds to consider in three dimensional modelling of an animal
If you want to create a video tutorial, think first if you want to do it just on the computer screen or you want to demo it in front of the camera. If you want your video tutorial to be showing just your computer screen, you need to use a program that can record everything that is happening on the screen.
One application you can try for this is CamStudio screen recorder. It is capable of recording all screen and audio activities on the computer and then you can save it as a standard AVI file. Visit CamStudio Free Streaming Video Software to download. The recorded video can also be saved as a streaming flash video in SWF format.
Using the software, you can record everything that you do on the computer including your voice. You can speak while doing the task on the computer and the program will record it. When you are done, just save it either as a flash video or in AVI format.
