Hi , While using the android device , i get troublesome .It is not hoped by this device .
What can be done ?
Error message :
The process android.process,
acore has stopped
unexpectedly. Please try again.
Force close
The process android get error
Please do the following and get rid of the problem:
Go to Home> Setting>Application>Manage application>Running Tab>Click on contacts Data or Storage>Clear Data>Then Force Stop within the process.
It is such a problem that it has no other solution without doing it. Of course it's for my opinion.
Thanks for asking
Hathy
Do you have your contacts backed up? To fix this problem, try uninstalling Facebook if that is installed. If you did not fix your problem then try the following.
· Go to Settings>Applications>System Applications>Contacts Sync Adapter
· Then press Clear Data, this error usually goes away.
If this does not work then try to clean the data on:
· Settings>Applications>System Applications>Contacts or Settings>Applications>System Applications>Contacts Storage.
If the problem is resolved, then restore contacts and reinstall Facebook and do not sync contacts with it again.
