How to download and install protected folder skin? I am very disappointed when the last time I downloaded a software related to this because it was not successful due to some compatibility reasons. Now I am using a windows xp operating system. Can you give me a safe step by step process on downloading and installation? Thanks.
Process on installing protected folder skin for Windows XP
There are many tools available to protect folders on your system. Make sure you note the password to unlock the folders so that you can use them when you forget the password. Store the password on an external device which can be accessed whenever you want. Before downloading the folder locking tool check the compatibility of the software with your system so that you do not face the same problem that you faced last time. The following are some of the widely used folder protecting tools:
1. Folder guard – You can get it here – http://ptf.com/download/folder_guard/21917/. See the screenshot below:
2. Protected folder – You can get it here – http://ptf.com/download/protected_folder/6743022/. See the screenshot below:
3. Folder lock – You can get it here – http://ptf.com/download/folder_lock/388/.
