I have Nokia E6 (Symbian Anna pre-installed). Can you suggest me the best Process killer Software that can be installed on my Nokia E6 (Symbian Anna) to kill unwanted / useless processes to save power and release memory?
Process Killer required for Symbian Anna updated Symbian^3
Kill Me Symbian s60v5 software is the best according to your requirements. It also kills the useless/unwanted processes and release memory and save power. This software is compatible with all symbian mobiles i.e., Symbian Belle, Symbian Anna, Symbian^3, Nokia E6, Nokia 500, Nokia C6-01, Nokia E7, etc.
LyanaHay
Hi,Â
 I will suggest you to use "Handy Task Manager" for nokia E-6 it is best for killing processes and handling applications. I have used it on my nokia N-8. It works really fine .
Apart from this you can use "Smartphoneware Best TaskMan " because
1) It gives you list of applications and processes that running on your device.
2) It shows you what process and program running on your device and where it is installed and how much memory it uses.
3) It allows you to quick start the favourite applications and you can easily kill any un wanted applications as well. You can switch between applications.
You may find it on ovi store.
