I heard about a newly released software called Process Lasso Pro 5.1.0.96 Final which is said to improve the computer's performance. Will it prevent the computer from freezing and from hanging up? Can you provide me details about this software? Are there any disadvantages in installing this software?
Process Lasso Released (performance booster)
Process Lasso is a sole technology that improves PC’s responsiveness, stability and system performance. During high loads Process Lasso’s ProBalance technology regulates the priority of running programs as though badly performed or excessively active processes wouldn’t hamper with your capability to operate the computer.
By taking full controls it can automatically stop undesired processes and log all processes. Limiting the number of instances a process can have, It prevents the process which is leading a PC to freezes and hangs.
After installing Process Lasso, it automatically starts working. You don’t have to do anything to improve system responsiveness and prevent stalls instantly but advanced users can modify the configuration.
Process Lasso Features:
Prevent processes from dominating the CPU.
ProBalance dynamic priority optimization.
CPU throttling.
Save process priorities for future instances.
Save process CPU affinities for future instances.
Gaming mode.
Foreground enhancing.
Limit permitted program instances.
Disallow programs from running.
Log all processes.
System responsiveness graph.
Stand-alone core engine.
Exceptionally low RAM and CPU use.
The software called “Process Lasso” is a process priority optimizer developed by Jeremy Collake of Bitsum LLC for Microsoft Windows. The program features a GUI that allows you to automate different process-related tasks like automatically restart process if “X”.
The ProBalance algorithm it uses works by adjusting the processes priorities dynamically to be able to keep the system responsive when there are processes or process that consumes very high CPU cycles. The program is not a task manager replacement. Though it has several task manager functionalities, the intent or goal of the program is to optimize and automate.
For users who wish to try it, go to Process Lasso homepage. It supports Windows 7, Windows 8.x, and Windows 10. For servers, it supports Windows Server 2003, Windows Server 2008, Windows Server 2008 R2, Windows Server 2016, and Windows Server 2019.
