Sam_Wood
30 points
Posted on - 08/04/2011
Can anyone please help me program my new belkin router? much appreciation in advance.
Process of Setting Up New Belkin Router
Connect your computer to the belkin router.turn off your modem and router. Turn on first your modem,wait for 5 seconds then your router,wait another 5 seconds.Once all the light are stable on your devices,insert the installation disc of your Belkin router into your CD drive;this will just do an autorun;and this will walk you through to program your router.
It is very simple and easy to configure a router. You have to follow some easy steps and you will be able to join the world.
Please take these steps:
Take the router and put in on when done plug the wire in it in the main port or first port of router.
Second take the other end of wire while the PC is on and running on windows plug the wire in PC port now see here that the light start blinking when you insert the cable in port. It mean that the physically connectivity is established between the computer and router.
Next you have to configure your account. It will be the settings your service provider provide you.
Do this go explorer and then type 192.168.1.1 and click go or refresh
A page will open in front of your screen now put your settings as your serves provider tell you when configured click on save and you are ready to connect all over the world.
I hope now you can easily configure all of your router devices.
