Process To Installing Mac Os On Vmware Inside Windows.
Hello everyone,
I am currently using Windows OS but at the same time I alsowant to work on mac OS. Please provide me the procedure to installing mac os on vmware so that I can work on both OS.
Thanks in advance for the help.
Answered By 0 points N/A #304600
First, you need to install VMware on your system.
Run win.cmd file.
Create a new virtual machine in VMware.
Choose Edit virtual settings to select mac OS. You can do this by navigating to VMware interface.
Select hard disk in hardware.
Hit on next, and then next on the other window, select “use an existing virtual disk”. Then selet next on the window appears and then disk file browse to the location where you downloaded the Mac OS, hit on Finish.
Hit on start to begin the installation.
