ProcessMaker having errors on Fedora Linux
Hello all.
After I install ProcessMaker 2.0.32.tar.gz on Fedora Linux, I received the error:
“Fatal error: Class'SoapClient' not found in /opt/processmaker/gulliver/system/class.soapNtlm.php on line 208
It occurred when I clicked the import option. The same also happens when trying to edit a process.
Any help will be appreciated. Thank you.
Best Answer by Lopiz Ton
Answered By 0 points N/A #95546
Hello Wexler,
Looks like the soap extension for PHP enabled is missing on your server system.
To install soap with root privileges type this command on a terminal:
Codes:
Yum install php-soap
Service httpd stop
Service httpd start
Then try to import the process again. Hopefully this will solve these issues.
Enjoy,
Answered By 0 points N/A #95548
If you want to be out of fatal error  of your mentioned software having installed,
You have to follow the steps shown in images.
Tarek Hossain.
