Processor That’s Best For Gaming
I think you should go for Intel Core i7-980X Extreme. It’s costly ($990-$1059), but it’s the right choice for you as I think. I am giving you some example features of it why I am telling you to choose this.
1. Number of Cores:6
2. System Clock Speed: 3.33 GHzÂ
3. Cache memory: 12 MB
4. Bus or Core Ratio: 25
5. Maximum Turbo Frequency: 3.6 GHz
6. Instruction Set: 64-bit
7. Maximum Memory Size:24 GB
8. Memory Types: DDR3-1066
9. Maximum Memory Bandwidth: 25.6 GB/s.
On the other hand it has Intel turbo bust technology with it, Intel® Hyper-Threading Technology and many new technology with it. If you want to have a stable gaming cafe you should go from this. You can check INTEL website for further information.
Thanks for the advice Rony. I want to replace my processor and was thinking of which to choose. I am following your choice and will buy it soon.
Thanks
