This product has encountered a problem AMT Subsystem Failure
I am using windows 7 on 64 bit platform. Yesterday while I was launching Adobe CS4, the following error appears which says,
“This product has encountered a problem which requires that you restart your computer before it can be launched.
If you continue to see this message after restarting your computer, please contact either your IT administrator or Adobe technical support for helps, and mention the error code shown at the bottom of this screen.
Error: 148.3
https://helpx.adobe.com/support.html
OK
At that time I was attempting to open a DREAMWEAVER.
I failed to solve the problem. So I need help. Please give me an effective solution for the error mentioned above.
