Hey. I need a solution to frequent Pro/E Crashes. While working on assemblies or switching between a few open parts, I often receive this message.
The assemblies I am working on are not very large, but still this issue is arising very frequently. Can anyone help me with this problem with pro/engineer and tell me the reasons for this behavior? I am running WF5. Thanks in advance.
Auto-traceback Info
Pro/ENGINEER has encountered a problem and will exit.
Select OK to generate a traceback file for Technical Support, or Cancel to exit. |
Pro/E Frequently Crashing During Use
Maybe you do not have enough resources on your computer that is why you frequently experience program crashing. While working on your project on your computer, close any other open applications.
Make your computer available exclusively for the current application you are using. Checking the application’s system requirements would also help determine if your system is really compatible to run the application.
You may also check your computer for any possible errors. Any errors in the hard drive’s file system can cause different problems to applications.
You may notice sometimes the application works a lot different than the usual. Use a disk utility application to check the system.
You may also scan your computer for any virus. Update your antivirus then run a full system scan on your computer. Computer viruses tend to slow down computer processing and creates different sorts of errors.
