Hi Experts,
I am looking for an installation creator which creates installers for my applications.Some key features of Install package creator should include Gui-based EXE setup creator, indicate installation path, adding of license agreements, text, icons, logos etc.with an option of uninstall program.
Can anyone help me in telling which one is the best freeware for creating installers for windows based operating system?
Professional Install package creator needed?
NSIS
Here are its features
Small size
Compatible with all major Windows versions
Unique compression methods
Script based
Multiple languages in one installer
Many features and checks for the target system
Custom dialogs and interfaces
Support for web installation, file patching
Portable Compiler
Click here to download it
Others may include
MSI installer
One great alternative and free option (funded by donations) that would aid you in creating installation packages is InstallForge. It counts with not having to be scripted and as such, it greatly improves manners of use; it also contains a neat ZIP creator which, in case you have some implements that would better fit the ZIP file system, can be made as such.
