Program about how to cut black frame in video please
Hi everybody,
I have some black frames ;I am asking if there is a program tutorial showing how to cut black frame in video, instead of editing myself it really needs time.
Thank you in advance
Hi everybody,
Womble is video editing software that includes an option for removing black frames.
Just download and install it.
Go to the 'blank fades' option and fix the format with output settings to split the black portion of your video files.
The official site of this software
To discover further, go through the web search.
Hello Roger Neil,
Are you using any Video Editing Software?
I would suggest using AVS Video Editor.
It is free and can remove black borders.
Just change the aspect ratio before editing.
It should remove the black frames.
There is no need for a tutorial because it is easy,
From the AVS Video Editor software, go to 'Edit', 'Aspect Ratio', then choose the ratio of the source file.
Hope this helps.
