Hi there,
After installing ArchiCAD this error stopped me to work with this program. I did a small research on the internet about this error and nothing useful was found. Please help me to fix this error. I really need to make a project to school.
Thanks experts!
ArchiCAD.exe. System Error
The program can’t start because GSQuickTime.dll is missing from your
computer. Try reinstalling the program to fix this problem.
OK
The program can’t start because GSRoot.dll is missing from your
OK
Since you did not mention what version are you using and since you are also on Microsoft Windows 7, it would be best to upgrade your version to the latest. You can download and upgrade to ArchiCAD 17. This latest edition supports Windows Vista, Windows 7, Windows 8, and Windows 8.1 all x64. 32-bit Microsoft Windows are not supported.
For Mac, it requires Mac OS X 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, and 10.9 Mavericks. For the hardware, it requires a 64-bit processor at least Core 2 Duo, 4 GB RAM, and a video card with support for OpenGL 2.0 and up. In case you don’t want to upgrade to ArchiCAD 17, make sure you install all the required modules for the program.
Because if you’ll look at your screenshot, the first image is referring to a missing DLL file associated to QuickTime. This means, your computer doesn’t have an instance of QuickTime. You can download the latest version from QuickTime 7.7.5 Download. It supports Windows XP Service Pack 2 and up, Windows Vista, and Windows 7. Aside from QuickTime, ArchiCAD also requires Java Runtime Environment [JRE].
To download, visit Java SE Runtime Environment 7u51.
