The program can’t start because MSVCR110.dll is missing
Hi tech savvy,
When I am about to complete the Cinema 4D installation, I stuck up with the system error. The error message says some dll file missing in the computer. I am not aware of any dll file, where I can find the missing dll? Do I need to install it separately? After a while I tried again to re-install the program but no luck. Really, I need help. Thanks
The program can’t start because MSVCR110.dll is missing from your computer. Try reinstalling the program to fix this problem.
