I just installed a new game on my laptop with Windows 7 and when I tried to open it this System Error window appeared. I have uninstalled the game, rebooted the laptop and install it again, but I couldn’t get rid of this problem. I really want to make this game to work so is there anyone who can help me to run this game and tell me why I have this error and how can I solve it.
Thank you!
The program can’t start because xmogrt.dll is missing from your
computer. Try reinstalling the program to fix this problem.
OK
Too bad you didn’t mention the name of the game you are trying to play to better check the problem. Anyway, if you already tried reinstalling it a couple of times and still nothing happened then there must be something wrong with the game itself and your operating system in terms of compatibility. To make sure you are using the legit copy of the game, download the game’s installer again from the official website.
When you are there, also check the game’s system requirements because your computer needs to meet all the requirements to be able to play it. Download and install the game again and see if it works. The DLL file “xmogrt.dll” is part of JuggerNET developed by Codemesh, Inc. “xmogrt.dll” is also the shared runtime library for Microsoft .NET Framework and Microsoft Visual C++.
If reinstalling the game didn’t fix the issue with “xmogrt.dll”, try downloading the missing file from Download File xmogrt.dll. I tried searching for a site that provides a download for this file but I can’t seem to find one. This is the best link where you can install the DLL fixer and restore the missing DLL file.
