This program cannot be run in DOS mode
I want to run the setup.exe in the DOS mode. But when I open the file using the DOS it appears the error this program cannot be run in DOS mode. Please can you give me any solution to solve the problem. As I try many solutions to do it but the error remains, and the problem always occurs.
Answered By 0 points N/A #186624
You can run the setup.exe file in the DOS mode. But you cannot directly run by opening the setup.exe  in the DOS mode.This is because setup.exe file is not allowed to run in the DOS mode. For running setup.exe in the DOS mode follow the below procedure.
To run the setup.exe file in DOS mode open the  Winnt.exe you can find it in the folderI386 folder
CD-ROM. Typedrive:i386winnt.exe, where the drive is the CD rom drive.
By following the above procedure you can run the setup.exe file in the DOS mode. As it will be impossible to run the setup.exe file in the DOS mode.
