Program to completely remote control phone
I have a program that allows me to use my computers keyboard to type on my phone, as long as they are both connected to the same WiFi. I love it, the only problem is I can't see what I've typed and still need to get my phone out of my pocket. Is there a program/app that would allow me complete access to my phone over my computer, including an image of the screen?
Answered By 0 points N/A #168312
Hello!
The answer for your question is YES. There are a lot of applications which can do this.
The best I've used so far is AirDroid, which you can download for free from Google Play.
airdroid remote control app icon
It has numerous features. You can type SMS messages through it, transfer files from/to PC/Phone etc.
If you have root access on your phone, then you can also see what is actually on the screen of your phone. Give it a try!
If, for some reason you didn't like AirDroid – check "droid VNC server" or other "VNC servers" for android. Remember that if you want to use VNC server – your device must be rooted.
