Program that convert NTSC to PAL OSX
I am using Mac OS X operating systems, I want to know about the program that comes preinstalled along with Mac OSX that will convert NTSC to PAL OSX. Please advice on how to locate and use it.
Hi Dave,
“iMovie” just does that, here is the simple process:
1. Launch the “iMovie” (icon is on the desktop).
2. Click “File,” then “Import Movie.” select the PAL file you wish to convert, it will then be placed at the bottom of the screen.
3. Drag the PAL file from the bottom of the screen to display time line within the iMovie application.
4. Click “Share,” then “Export Using Quick Time.”
5. Click “Options,” “Video,” then “Settings.” Click “Compression Type.” Choose NTSC,” “OK,” then “Save.” The PAL file will then be converted NTSC.
