The program crashes when I search 123 JavaScript library
Hi guys.  I just installed 123 JavaScript Slideshow as a slideshow builder for my online JPEG files.  When I'm trying to search 123 JavaScript library for the JPEG files, the program will immediately crash.  What could be the problem?  I'm on a Windows 7 64 bit system.
Answered By 0 points N/A #198481
Hi Dorindagmincey,
Good day! the problem might occur when your program is corrupted on its library, the corruption on the library won't affect well the whole program so the program will work well not until you have called this particular library files .DLL, I want you to search for the library file on its installation file > lib folder and check if the file is corrupted or not.
