We use Visual Superscript. When we are trying to open the Visual Superscript on the main computer we were getting the error:
” Program error.
Cannot create file.
C:docume~1tomhea~Locals~1tempvisworkstationtemp.dbc”
Please help to solve this problem. Thanks.
Program Error – Cannot Create File
If you are not allowed to access or delete a folder or file, try the following steps:
1] Restart your machine and do not start any program. Navigate to the file and remove the file.
2] If message persist create file operation is not permitted than drop a note to the IT Department.
You can also find tools that are free and one can resolve the issue without much hassle.
HTH!
Hi Donald B Roman,
Reason why such error occurs might be strongly related to disk space availability.
Try to find out how much disk space you have in the free state and also consider creating some free space in the logical file. Delete unused docs, backup, junks, whatever you think is not necessary.
In case you have already performed above steps, then make sure if permissions and file name validity are ok.
