A Program Error Flash.exe has occurred
Posted on - 02/22/2013
While installing the Flash CS5 on Ubuntu (with Wine), this error message appears:
Program Error
The program Flask.exe has encountered a serious problem
and needs to close. We are sorry for the inconvenient.
This can be caused in the program or a deficiency in
Wine. You may want to check https://appdb.winehq.org/ for tips about
running this application.
If this problem is not present under Windows and has not been
reported yet, you can report it https://bugs.winehq.org/.
