Program Error on installing Photoshop with Linux Debian
I had a Program Error after installing Adobe Photoshop 7.0 in my Linux Debian. I re-installed the program but still encountered this serious problem when running Photoshop. Is there a way that I can recover from this problem?Can someone please help?
Error:
Program Error
The program Photoshop.exe has encountered a serious problem and needs to close. We are sorry for the inconvenience.
This can be caused by a problem in the program or a deficiency in Wine. You may want to check https://appdb.winehq.org/ for tips about running this application.
If this problem is not present under Windows and has not been reported yet, you can report it at http://tugs.winehq.org.
Close
