Program Error Message on Microsoft Outlook
This error below is only available on MS Outlook.
Error:
I'm sorry,but a serious program error (Cannot access a disposed object.
Object name: 'IndexerNotifyForm'.) occurred.
Would you like to send a bug report (don't worry: you will be able to review all contents before the report is sent)?
I have been working on SQL server coding, and I want to know why this error has existed.
Do you think that it is safe to click on YES?
Answered By 590495 points N/A #150775
If you are already using Microsoft Outlook before and this is the first time the error happened, try restarting the computer then try again. It could only be a fluke and nothing serious. But if the error appears again, try uninstalling Microsoft Outlook. If this application is part of Microsoft Office package, remove only this feature and not the whole Microsoft Office package. After that, check your computer for any possible errors. Use a disk utility application to check the system. Next, install Microsoft Outlook again. This will fix any corrupted files in the installation and will restore the settings back to default.
If this doesn’t help and the error still appears, try doing a clean installation again of the whole Microsoft Office package. Uninstall Microsoft Office from your machine. Restart the computer if the system asks you to. Install the package again after booting the system.
