lizgriffinn
10 points
Posted on - 08/25/2011
I download many version of Flash CS5 from internet after downloading I install it in my pc but after 2 or 3 minutes I receive given error. I make a ghost of my system for removing this error I run ghost and again install this software but again appear below error after it I download portable Flash CS5 but same error appears. Detail of Error is below.
Program Error
The program Flash.exe has encountered a serious problem and needs to close. We are sorry for the inconvenience.
This can be cause by a problem in the program or a deficiency in Wine. You may want to check https://appdb.winehq.org/ for tips about running this application.
If this problem is not resent under windows and has not been reported yet, you can report is at https://bugs.winehq.org/.
Close
This error tells that there are some corrupted files in the folder of the flash where it installed. So you must focus on those files. The solution for you is that you can open the control panel from the start menu and then start add/remove program and then there you found a flash player. There you found a button named as uninstall so press that key and then repair that software in a new way and then try to run it if again it shows an error then you can install that player in a new way or simple get a new copy of it .Thanks.
That is not a Windows operating system you got there. If you want to install Adobe Flash CS5 on Linux, you can do it under Wine. That’s how you install Windows programs on Linux: using Wine.
For Wine, go to WineHQ and download the latest version. Once Wine is updated, install Adobe Flash CS5 again. “Wine” stands for “Wine Is Not an Emulator”. It is a compatibility layer that can run Windows applications on select POSIX-compliant operating systems like OS X, Linux, and BSD.
With Wine, instead of simulating internal Windows logic similar to what a virtual machine or emulator does, Wine translates Windows API calls into POSIX calls on-the-fly. This removes the performance and memory penalties of other methods therefore allowing you to cleanly integrate Windows applications to your desktop.
