A program for running pc very fast software
Hello techyv.com!
I have here a PC and its OS is Windows 7, RAM is 2gb. Now these past few days, I've noticed that my PC runs unusually and I want to do something about it for it to run smoothly again. Is there something that I could download for running PC very fast software? Thanks!
Best Answer by oliverpowell
Answered By 40 points N/A #176707
There are so many software or application are available online, Which can boost your PC performance, Thats what they claim, Now before you download such application, I would advice you to take care of your PC, Through Disk Clean up, Deleting Browsing history, Temp Files etc, These few step can make your PC faster, Now here is the link below, Where you can download the software, That you've mentioned above,
http://www.pcbooster.com/solutions/pc-booster/
Thanks
Answered By 50 points N/A #176708
Dear Pearson,
Thank you so much for stopping here and I'd glad to assist regarding the query you've.
Installing more and more heavy programs specially provided by the third party makes your PC running very slow. It may also be possible that some of the faulty third party software would corrupt registries or damage system files. In both the cases, you'll notice your PC for becoming unstable or behaving abnormally.
I'd strongly recommend you to install any or all the programs that consuming more and more system resources. You can check out about which programs are more heavier when running by right clicking on task bar, choose task manager and navigate to tab named 'Processes'.
Alternatively, you can also switch to remove programs from control panel and free up some space.
One last thing to do is to run disk cleanup for every drive you've on my computer.
Post back if you're still facing problem or above steps doesn't give enough PC speed as before.
Thanks,
Oliver
