Program that will create a Hotkey
Is there a program that helps in creating a hotkey that when you type in the combination keys, a set of line of text that you predefined will appear automatically? For example, you assign [email protected] for the combination key ALT+SHIFT+M, so whenever you use the hotkey, the e-mail address you predefined will appear instantly. This will save me much time so I don’t have to type in the same line of text again and again. It’s like more of a shortcut. I know AutoHotKey feature but wasn’t able to grasp the tutorial on how to assign a hotkey because I’m not able to follow the directions in the tutorial that use high-sounding words. Reading the tutorial just gave me headache. I just want a simple procedure on how to do this. So please help.
