Programs not working on other Computers
I have a computer games and my classmate asks for a copy for her computer, but when she pasted it on her PC it doesn’t work. What Should we do about it?
Hi Conan,
About your computer games. can i ask? how did you get your games? still copy and paste or you install it? there are games that cannot be copied because you need a CD/DVD to play, without the CD/DVD you cannot play. There are games you need to install it and get the serial key or the product key after you to install it and play. Not all the games can be copied and pasted it to your computer and play. Some games are software protected which is you cannot fully copy the games or software. Or there are games which are not compatible its either 64 bit or 32 bit and check for the minimum requirement for the games. Tell your friend to buy the original copy. Note: look the minimum requirements if it is compatible with his computer.
If someone copied a game from you but it doesn’t work on your friend’s computer, problem there most probably is compatibility. To see what’s wrong, check the game’s system requirements then verify that your friend’s computer meets those requirements. If your friend’s computer is not compatible, either upgrade the system or try installing a different game.
If the operating system is supported but it still doesn’t work, remedy for this is to update the operating system to the latest Service Pack. If you have Windows XP, you need to update to Service Pack 3. Download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP.
If you encountered an error when updating to Service Pack 3, try updating to Service Pack 2. Download Windows XP Service Pack 2 if you don’t have it yet. You can update to Service Pack 3 once Service Pack 2 is installed. For Windows Vista, download Windows Vista Service Pack 2. This is the latest and last Service Pack update for Microsoft Windows Vista.
For Windows 7, download Windows 7 Service Pack 1. This is the latest and only Service Pack update for Microsoft Windows 7. For Windows 8, update to Windows 8.1 from the Windows Store.
