Project 64 1.6 Unhandled Error messages and how do I fix it?
Hi all,
I keep on getting the following error message "Unhandled R4300i Opcode at: 801E7400 Unknown 73 73 00 00 Stopping Emulation" Zelda Ocarina.
I’ve searched the net for help but came up empty so can someone please tell me what this means and how to stop it!?
Thanks in advance for any help.
Answered By 590495 points N/A #138453
I think your problem here has nothing to do with your operating system. The Project64 v1.6 that you have is a Nintendo 64 emulator that works on all versions of Windows.
If you are using a different operating system other than Windows then this could be what’s causing your problem. This emulator works only with Windows.
It has a beta version, Project64 v1.7, which is only available for paid members or those users that created an account on their website and made a donation for the ongoing work of the program.
I am also using an emulator but for the PSX type or the PlayStation 1 model. I also encounter this kind of problem in the emulator that I am using and can usually be fixed by changing some of its configurations in the emulator’s settings.
You should check the program’s configuration for the particular game that you are playing. Sometimes different games require a different configuration that’s why some of the emulators include a profile for every game that is played.
