jazzreyes
Posted on - 02/23/2012
How comes I receive an error message stating that “The project item cannot be copied” when I try copying the macros that I drafted myself to a certain document that I am editing?
By clicking Normal area “New macros name” then clicking “”Copy”.
I am wondering if this is due to the fact that on clicking the organizer button I only have the option of copying these macros from the “Normal” area as the “All” area option is missing.
I have been unable to figure out this problem so please help.
The project item cannot be copied Error while copying MACROS
Hello, I'll teach on how to fix this problem. Just follow the Instruction carefully.
1.Exit MS Word. If Word is used as the email editor, close Microsoft Outlook.
2.Go to menu click My Computer and then find the Office Startup folder.
The default location is C:Program FilesMicrosoft OfficeOffice10Startup.
(Example Picture)
3.Then make a new folder and drag each item from the Startup folder to this folder.
4.Look for the Word Startup folder. The Startup folder is C:Documents and Settings[user name]Application DataMicrosoftWordStartup.
5.Move each item from the Word Startup folder to the new folder.
6.Open up MS Word. In the event the error message no longer seems, something within the Startup folders causes the issue.
Manually include each item to it's original folder to see which causes the error message.
Regards
Iwillgivethenamewhenhired
