Hi TechyV buddies!
I have encountered a problem on opening a client site specifically in the project server forum. When I create a new portfolio analysis and click the new button, I end up receiving this error image.
Can anyone help me solve this problem? Thank you!
Project server 2010 New portfolio analysis error#PS2010#SP2010#MSPROJECT
It seems that you forgot to insert the image or the screenshot of the error message you got when you encountered the problem.
If you are using an application when the error happened and this is the first time this happened, try restarting your machine then try it again. See if it works after restarting the system.
You may also try doing a clean installation of the application to restore it to its default configuration and fix any corrupted or missing files in the application. Uninstall the program then restart your computer.
After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics tests on your machine, use a disk utility application like Norton Utilities.
Install the application again then see if you are now able to use it.
