Hi! I connected my new projector to my laptop but the picture appears on the board with red color, so white font for example looks pink and the rest also has some red color in it. I checked the menu, letters were showing with regular white, so there is nothing bad with projector I assume. I reinstalled drivers and everything, still the same.
Projector shows picture in red in the board
If the device is new and appears to have no physical damage (e.g., cracks, irregularities, dents, scratches, loose or missing components, burns), it appears that you have an issue with calibration and configuration. I would suggest that you first review the configuration for the device on your PC. Use the software bundled with the device to calibrate and configure the device. There should be a series of tests you can perform with the software. Also, update your operating system. Check the websites of the device manufacturer and your OS for the latest drivers. You can also download a configuration utility for the device or a live (linux) operating system exclusively for using devices like this.
